Fresh Install Error
While trying fresh install I got this error. Any help?
@Jayanta-Das It tried a fresh install on Windows 10 with the current downloaded msi and it seems to be working.
When installing VS with the MSI installer, there is a possibility to set the app path.
Was this changed?Also: was there a VS installed previously there, if so remove using the Windows Settings
@VectorStyler I didn't change anything (path), keep everything default. Yes there was previously installed VS, for some reason the launcher shorcut was not showing in app list in windows start. So, I thought installing VS again over the previously installed will fixed this. Also tried after uninstalling the previously installed, same error shows.
@Jayanta-Das Not clear what could cause this. Try an older version from the release page: https://www.vectorstyler.com/releaselog/
@VectorStyler I did try version .54 but same error
@Jayanta-Das Searching for this error, this is what I found: https://appuals.com/fix-the-feature-you-are-trying-to-use-in-on-a-network-resource-that-is-unavailable/
