A node selection issue that slows node editing
  • I frequently bump into this click-and-drag (box select) issue where
    after I select a single object in order to edit only its nodes, the first
    click of click-and-drag can still select and bend the segment of an
    unselected shape by mistake:
    alt text
    As you can see, I'm bending the segment of the other shape if I'm
    not careful to start the click-and-drag exactly in the empty space
    between them.
    Can somehow any interaction with an unselected shape be disabled
    when clicking-and-dragging once a shape has been selected and
    you're in node editing mode?
    Is there some drawback to this more restricted approach?
  • @b77
    something like this also happens to me from time to time
    and when you drag from the inside ?
    or use the lasso selection in these cases?
    came to my mind.
    the pointer seems to me here in certain areas
    a bit too sensitive, maybe it could help if we
    could regulate the sensitive range size ?
    short video here
  • @b77 said in A node selection issue that slows node editing:
    I would also like to know this.
    I am experiencing this problem when using lasso tool. I have already learned that the first click has to be away from the objects, otherwise I make an accidental edit. I definitely join the request to isolate selection. It can be as an option.
  • @Subpath I agree that there is also the opposite direction alternative for box select (from
    lower right to upper left in this case) but it's not the default way to box select โ€” you need to
    pause for a second, "inspect the area" then decide to click-and-drag like that. All this adds
    up and it slows you.
    @encart Thanks, you're right, it also happens with the Lasso tool. ๐Ÿ‘
    Just to make sure there's no misunderstanding:
    It's good that the app lets you select nodes from all shapes when nothing is selected,
    so I wouldn't change that. That's fast.
    It's just that once a shape is selected, it's not in complete isolation mode for node
    selection โ€” while nodes from the unselected shapes are not included when you
    click-and-drag over them (which is great), a misplaced click on a segment of
    another shape will interact with it and bend it.
    @b77 Added this to the backlog. Not sure yet of what is the solution here.
    The problem is that click+drag should be able to move nodes / segments.
  • @VectorStyler said in A node selection issue that slows node editing:
    OK, but by 'click-and-drag' i meant 'box select'.
    That should not select and bend any segment of any other shape than the selected one.
    If it's doableโ€ฆ ๐Ÿ™‚
6 out of 6
