Is there an easy way to determine the angle of an existing edge of a shape or path?
Is there currently an easy way to determine the angle of an existing edge? If I wanted to know the exact angle the square is at, is there a way to click on that edge and get that info somewhere?
@Boldline If it is a path, then select the node at the end of a line and the Path panel will show the angle.
