Shapes edited with transform tool prior to converting to curves have odd results
This seems like a regression. Shapes drawn and adjusted prior to converting to curves produce unwanted issues when pulled with the transform tool
@Boldline Is the "Transform Stroke" option enabled?
@VectorStyler yes, if you're referring to this setting in the document preferences
I restarted VS entirely and now it works. Previously I had closed out all the open files and made a new one and it had persisted. Should have tried that as well before posting. Solved for now. thanks
The issue eventually returns and requires a restart of VS to correct it. I saved the messed up rectangle and pasted it in a new file alongside a working one in case that might help figure out the issue
Here is the file: 0_1687145455729_rectangle issue.vstyler
@Boldline I will try to find out what could cause this.
