Ideas to improve the Vectorstyler Layers Panel
@Boldline said in Ideas to improve the Vectorstyler Layers Panel:
the unpleasant need for guidelines
A more complicated alternative could be that if you hover over the panel, the lines for the underlying layer (only a single layer row at a time) become visible and give the desired reference.
I don't know if VS also has aspirations for iPad like devices. Then hovering is not applicable/ideal to my knowledge.
@Ayo said in Ideas to improve the Vectorstyler Layers Panel:
Like so...
or so...
Like so...
Like so or so...
In retrospect, I don't think it is a good idea.
The vertical guidance for fast toggles (slide up/slide down) is lost.
@Ayo I like your new layer panel a lot. Here are my 2 suggestions:
- A vertical triangle - the "play button"
 next to the layer's color, should be light in color in dark mode - as it is now.
2. Is the "play button" even needed when the layer is empty? It suggests that the layer can be expanded and contains some elements, but this is not true.
In my opinion "play button" should appear if the layer contains some elements.
@Harry said in Ideas to improve the Vectorstyler Layers Panel:
You are absolutely right.
Just like the filters right side and magnifiing glass left side. Quite a difference!
Thank you,
Attached corrected version 2Is the "play button" even needed when the layer is empty
Theoretically not, but it is a good indicator that you are dealing with a Layer. At least that's how it is now.
I can understand this but I agree with @Harry that it gives the impression there's already more there.
If a symbol was added to the layer to designate it an art text, shape, bitmap, etc object, a symbol could also representative of an overall layer as well.
@Ayo Great that you started a discussion about the Layers panel.
I can't say I would change the 'eye' to a 'validate' sign — it's a bit too disconnected
from the idea of 'visibility'.Visually, I like the idea with the 'lock' icon being displayed only when the object
is locked. Same with the 'eye' icon when the object is visible.However, with all the lock buttons being invisible because the objects are not locked
by default, the developer might get questions like 'Where's the 'lock layer' or 'lock
object' button in the Layers panel?'.So a third alternative could be an 'eye' and a 'lock' button that are very close
in color to the background color, so they still can be seen.And the triangle button for empty layers (see 'Layer 5') can adopt the same color.
Like this:
As you can see in the image:
A slightly darker background under the objects and no separators gives a cleaner look.
Also: vertical lines on the sides are not needed. I'm not even sure those between the
eye, lock and triangle buttons are needed.And since the color IDs of the layers might be the least important indicator, I made
them even narrower than Ayo, AND I placed them on the right, after the
'selection' button.Bonus benefit: they are away from the colored thumbnails.
There's also room for improvement with the icons at the bottom, but I'll save that
for another time.
@b77
The task is not to create as much difference as possible, but to create as much clarity as possible with as little difference as possible.For me it is not about visibility but about on/off.
Checkmarks meaning 'on' are used all over the program.Would be fair to compare your variant next to my proposal.
Could you show that?
@Ayo Sure, here they are:
Are there other graphics apps using a validation sign in the Layers panel?
Btw, i made the 'eye' icon filled. It looks better than the current icon.
@Ayo I also sent a PM with a link to the .vstyler file. Feel free to modify it.
@b77 said in Ideas to improve the Vectorstyler Layers Panel:
'selection' button.Like the Color ID half width at the far right position.
It's not unusual. Grabbed this collection...
I would like to say that I really appreciate the effort you put into this
and also the graphic presentation.@b77 version looks a little more pleasing to me. The eye could be
replaced with the hook idea, have nothing against it.But I would make the hook a little smaller and/or maybe
a little thinner, as I think it stands out too much.
@Ayo Well, I personally still like the filled eye better. And since most new users are coming
from AI, CDR and AD…On the other hand, looking at Amadine's slim layer color IDs, I'm tempted to suggest
the same for VS.
@b77
Agree. In addition to my aforementioned substantive preferences, The checkmark is calmer than the many eyes that stare at you.Dimming the empty layer triangle confuses me. Looks like layer or something is disabled.
Would an empty triangle look better? Empty shape —> empty layer.
We must be careful not to get bogged down in a discussion of details led by personal preferences. I am glad that the basic concept is being embraced. There is now enough food for thought for the developer to make his own choices if he wants to bring this idea to life.
We should not only focus on the design of the panel alone, but also in conjunction with the style and concepts used in other parts of the program.
A closely related panel is the Appearance Panel. The same principles can or must also be applied there. If the Layers Panel is going to change.
I come to a summary below of course from my preferred point of view.
Of course there is still more room for improvement. In line, color, level separations and icons of course. To avoid exponential numbers of variants you would first have to make fundamental design choices. We could proceed from there. But that's up to the developer.
Speaks for itself, but the following things have been done at C.
- Color IDs to the right
 - checkmark lighter weight
 - gridlines darker (instead of lighter) in Dark Mode
 - removed border Color IDs (not shure if that is wise)
 - some more new icon suggestions in footer.
@Subpath Tanks!
For me, I can definitely say no to the many attempts at improvement I see in Affinity and other programmes. They don't succeed because there is usually a confused effort with no science or UI education behind it. And yes, I work with usability every day.
Keep it simple!
In v2, Affinity has completely destroyed the most important thing in the layers panel for me, a quick overview of the content. A complete amateur chaos of lines and icons - and Serif did this because they think they can do without UI specialists. I don't lock, colour or hide objects all the time, but I navigate the left side of the layers panel constantly and all the time.
It is absolutely crucial for me that the structure of the content and thumbnails are easy to read for quick use (left side with no Linux grid and symbol spaghetti), and the name afterwards is important, secondary. After that, locking and hiding content is less important - on the right side, for WHEN I need it. Tertiary.
I guess this can be solved with customisation options, but basically my message is, FFS, don't ruin the current simple layout for me, which works great in designs with hundreds of objects.
@Ingolf said in Ideas to improve the Vectorstyler Layers Panel:
I do!
Keep it simple!
Totally agree!
@Ayo If the developer would implement 'Auto-lock' for inactive layers (meaning that
you can select objects only on the active layer(s) and switching to another layer can be
done simply by Cmd-clicking an object on that other layer), the 'lock' button for layers
could be left somewhere on the right.And btw, since you work in cartography, would an optional 'Auto-hide' for the objects
on inactive layers go well with this auto-locking of layers?@Ingolf If possible, can you include two screenshots with v1 and v2 of AD's Layers panel?
I searched them a bit but I'm not sure those I found are not from AD's Pixel "Persona",
which might look different (I guess).
I'm not that fond of 'Auto' or self-thinking functions
