Crash Report misses 'Send'
Three times in a row. Lost my drawing three times.
Try to make a drawing about drawing places a next issue
It is a combination order of; switching drawing place modes, drawing, dash-line setting, cut paste screen dump/text.
If I try to extract the problem I cannot replicate it.
Now saving a bit more.Sent this in a crash report but I think it does not arrive?
I hit the button close because there is no send button.
Not even if all data has been filled in.
@Ayo "Close" should send the crash report.
I received some crash reports (dated today, 15:05). The root cause of this crash has been identified and fixed.
The fix will be in the next buildEDT: the document should be backed up when a crash occurs. Is there a notification at the restart of the app?
@Ayo The crash is caused by the drawing place button in the context panel:
@VectorStyler said in Crash Report misses 'Send':
Indeed. Figured that out too.
This is what I get. No notification of backed up files.
@Ayo I will look into this issue with the backup files.
These should be located in ~/Library/NumericPath/backups/ folder.
~/Library/NumericPath/backups is empty, no folder nor file.
@Ayo said in Crash Report misses 'Send':
It means the backups were not saved
Do you have the backup save turned on in the document settings?
@Boldline
I'm afraid not. Thanks, that must be it
@VectorStyler Should this be turned on by default in VS? Seems like most people would prefer to have this ability from the get-go
@Boldline
At least useful for a Beta version.
Are they automatically deleted after a real save?
yes they should be
