Because you mentioned tables and graphs, I had a vague
thought of referring you to βcavalry.β I wanted to at least
mention it.Here the Link
https://cavalry.scenegroup.co/
@Subpath Thank you for the link. I will check this app.
@syllie said in Affinity Designer vs VectorStyler:
@gotanidea But AD can after all these years still not do RTL text. It is laughable. Just think how much of the world population they exclude as potential users by not having this solved.
AD is disappointing in terms of advanced vector illustration features, but its stability, performance and graphic design tools are on a par with Adobe Illustrator's. AD/ VS have their own strengths and weaknesses.
@syllie Agree. Language support is a mess in AD. I really struggle when adapting artwork to South Indian languages. I use Amandine (https://amadine.com) by Belight Software, which is hardly a 40mb size app and handles it very well.
just like to add, that "cavalry" is made for procedural vector animation
( sometimes called Mograph for vector animation )its file saving is a bit unique, instead of saving a file you render it
to save it. But its also possible to copy a Result as .SVG to the
Clipboard to use it in a another app. btw you can also render a
vector animation in lets say 20 single vector filesits for animation but renders also stills, there is a free version
its a offline app (but you need a online account) and some
versions are subscription based
@Kumr We are more limited on Windows but our options have improved from what they were before, thankfully.
@Subpath Its interesting app and have potential. With a little patience, it may be possible to accomplish some (or most) of those effects using VS.
@debraspicher Yes, VS is evolving.
@Kumr said in Affinity Designer vs VectorStyler:
of course
VS offers many possibilities to do things, thats is why it is my
favorite and main program for vector graphics.The interesting thing about Cavalry was, for me, the way
how different parameters can be linked to each other.
@Subpath For all my new projects I'm using VS, slowly moving away from AD. For image editing I am using Pixelmator/Photomator.
Cavalry is definitely interesting in that aspect. One more app may be worth checking out in this context is 'Paragraphic' (still in development) by Lostmids, the same company that developed Vectoraster.
thanks for the tip, also interesting but its Mac only
In the next few days I will post a possible solution
for Windows users, there is still a bit of work to be done
They mentioned that it will be a cross platform app. (https://paragraphic.design)
for Windows users, there is still a bit of work to be doneI am on Mac but curious about it.
will let you know
For myself, one of the primary advantages of Designer over VectorStyler is simply performance. I tend to work with more complex vector work/art, and where Designer works absolutely smooth, VectorStyler lags and stutters.
Illustrator, PhotoLine, and Inkscape also perform much better with the same vector files.
Of the lot, Designer and (surprisingly) Inkscape work the smoothest on my Windows 10 system (3080 12GB, AMD 7900X, 128GB Ram).
Inkscape used to be absolutely terrible. But the latest version works smooth and fast.
Dare I say? A tiny bit smoother even than Designer. I can tell now that I work on a 144hz screen.So, between the various apps my experience is that (with the same complex files) InkScape, Illustrator and Designer allow me to work smoothly with those files. Zoomed in, I reluctantly admit that InkScape actually wins (never thought to see the day).
And I am talking about a huge difference measured in frames per second. Where Inkscape and Designer feel smooth when dragging groups of items and transforming them (50-60fps or more), VectorStyler hits a framerate of:
...3 frames per second...
Illy sits around the 40fps. A tiny bit less smooth to work with.
PhotoLine still hits ~20fps (and speeds up to ~40fps when zoomed out), which is workable. And that app is not optimized for vector editing (more meant for high-end image editing).
All apps tested with the same SVG file.
So while I love VectorStyler's expansive tool set, I'd like to see some dramatic improvements in the performance stakes.
I tried all performance settings in VS, including turning on CUDA, multi-threading for all settings... But CUDA only slowed it down to a crawl, and multi-threading didn't really make much of a difference either.
Perhaps it is only my particular machine, though, that VectorStyler has issues with. Not sure. I read about other accounts on these forums with similar issues, so I am inclined to think it is something about the core of VS that limits its performance.
@Bones said in Affinity Designer vs VectorStyler:
I've also compared the performances of the vector illustration software with the text below and I believe Inkscape is the most performant one:
Text for performance comparison
To compare their performances, try to add more text into the textbox. For example, type "lorem ipsum dolor sit amet" at the beginning of the text.
If you have some vector files with performance issues, please send it to csraba at vectorstyler.com I will try to find out what could cause this.
CUDA will not affect vector rendering speed (it is for image effects).
These are enabled by default.
I also run tests on vector rendering here (all sorts of Macs and Windows) and I did not notice these issues.
There still are some open issues with text editing (under some conditions as shown in the file attached by @gotanidea) and these will be fixed.
@VectorStyler I will send you the sample file tomorrow.
@gotanidea Text rendering is a very different
kettle of teatesting context.I tested your test text in various apps. First editing text. Then moving the entire text box.
Illustrator has no issues whatsoever. Text editing works without lag, and moving the text box is entirely smooth at any zoom setting. Zooming in and out is fast and responsive.
PhotoLine has no issues with text editing, just like Illustrator. Moving a text box zoomed out also no issues (not as smooth as Illy). Zoomed at medium level moving the text box is a bit laggy. Zoomed in close moving the text is quite snappy again.
Zooming in and out is laggy when a lot of the text is rendered on-screen, though. -
Affinity Designer has no issues whatsoever while editing text. Moving the text box is very laggy at perhaps 2-3 frames per second. Text content cannot keep up with the movement.
Zooming in and out is fast and responsive though. -
Inkscape introduces long delays when editing the text. For a short sentence it may take a few seconds before it updates. Not workable. Moving the box is ever so slightly more responsive than Designer (or about the same).
Zooming in and out is somewhat laggy. Like PhotoLine it stutters more when a large text amount is rendered in the view. -
VectorStyler also introduces a lot of lag during text editing. It takes around a second for a new character to be typed. It is unworkable.
Moving the text box zoomed out is about as fast as Inkscape, but the text is greeked out. Zoomed in a tad to display the actual text halves performance.
Obviously this test is more academic than anything else. Yet it does show a general performance problem within this context with both Inkscape and VectorStyler. At the very least text editing shouldn't be affected that much by text quantity. Not when three other apps have no issues whatsoever with text editing.
Thanks for the tests.
@Bones There will be improvements in the (near) future for the rendering speed on Windows. Clearly there are problems when large number of gradients are mixed in with vectors.
Affinity has spectacular performance; it must be built into the fundamental architecture from the bottom up. I have drawn really complex things in Affinity with effects and gradients by the hundreds, and my very old laptops with those ridiculously simple Intel graphics chips built into the motherboard delivered an impressive effort. I actually never really noticed such low performance that it got in the way of what I was doing. I hardly noticed it. And then, on these low-spec Windows machines, I was free from the driver issues that are on Windows with advanced graphics cards, which ultimately moved my work over to 100% Apple equipment on M1 and M2 chips, where I have worked wonderfully smoothly since.
My sense is that programs built up without such a fundamental focus on performance will have a very hard time achieving it by optimizing and refactoring. My good experience with Affinity on terrible hardware makes me smile when people talk about needing hardware that can almost run ChatGPT to use graphics programs seriously. No, not according to my experiences. My experience is probably that people buy and put 20 Porsches in front of a grain silo on roller skate wheels and do not see the potential for improvement in the actual silo they are pulling.
Just to say, optimizations can be a long haul with less effect if it happens from the top down. I have experienced this so often with software.
