Erase block still not erasing only selected shape
@VectorStyler said in update 1.2.030:
Erase block modifier to work on selected shapes only.
Using the new build (30) this does not seem to be fixed. Here is a video showing this
@Boldline Was is selected in the Context panel in the Source drop down?
@VectorStyler That was the issue - thank you!
@VectorStyler I really like the option in the contextual menu to be able to choose between selection/layer/canvas (now that I know to check there first!) What about adding an option for same-style?
@Boldline said in Erase block still not erasing only selected shape:
The problem is identifying the style. Could be the current color, but that will handle solid fills only.
