"Shift+Click to deselect a single selected object" issue
Box Selection Mode
Transform Tool, Deep Select Tool or ShapeToolShift+Click to add multiple objects to a selection.
Shift+Click a selected object to deselect it.Issue: A single selected object can't be deselected by Shift+Click'ing
Deselecting a single selection by Shift+Click works when mode is Lasso or Polygonal Lasso, just not Box.
(I can always Ctrl+Shift+A or Click in the void or Click the selection indicator in the Layer Panel)
BR/ Lars Herold
1.2.030 Win11
@larsherold
Box selection works just fine here.Drag 1 [shift] drag+2 [shift] drag-2 [shift] drag-1 empty!
@larsherold
Transform tool selection, deselect first, works not.Click 1 [shift] click+2 [shift] click-2 [shift] click-1 NOT empty! Keeps selection. Esc then...
@Ayo
Agree!
Box with Shift+Drag works to select and deselect back to an empty selection.
Lasso with Shift+Lasso'ing works to select and deselect back to an empty selection.Only Box with Shift+Click will not deselect a single selected object.
Yes, I can Escape to deselect all - but there is a (small) inconsistency in the selection logic here..
@larsherold Box+Shift Click issue can be replicated here. I will fix this ASAP.
