@Li-Xiao These are for further down the road.
The opened a bug on the svg import issue.
@Li-Xiao I could not download the svg file, it seems to be a binary file
@VectorStyler said in Regarding the halftone repeater types:
i tried it also and get only a bitmap
seems a wrong file extension
It seems like uploading it again didn't make a difference.The zip file should be fine now.
0_1718440087305_String Art.zip
@Li-Xiao , is ok now
The Repeater is missing a fundamental feature: keep the original arrangement of all objects or text.
Lately, I've been needing this frequently, but I can't find any method in Repeater; I have to resort to using other software.
@Li-Xiao This would not be a repeater feature anymore, but something else. I have a new feature planned for the next version, that is a "live" adjustment to a group of objects, using the adjustment tools of the repeater.
@VectorStyler Thank you so much, looking forward to it!
Btw, in the recent versions, adjusting number values for Blended shape in the Repeater does not work.
I will try to find out what can cause this.
I cannot replicate this. Can you send me a file where the number value is not adjusted? Thanks!
@VectorStyler Sorry, I've been a bit busy lately. I didn't explain clearly. I meant multiple blended shapes, not a single blended shape. I couldn't find the files I make on before. I'll redo them when I have some time and send them to you.
