update 1.2.040
VectorStyler 1.2.040 release notes
- Improved offset stroke handling for thin stroke width.
- Added settings to cache symbol instances.
- Fixed a bug when flipping objects that are already transformed.
- Allow setting default stroke options from the context panel also.
- Highlight layer name by default in object options view.
- Fixed a bug in the select inside shape feature.
- Fixed a bug in fill and stroke style handling of text shapes.
- Automatically determine alignment direction when aligning side by side.
- Fixed a Unicode exception issue with capitalization in the Turkish language.
- Fixed a spacing issue in the wave and zigzag grid shapes.
- Consolidated the context panel options of the Pen tool into a single button with a menu.
- Fixed an issue with importing arrowheads from AI files.
- Automatically close filled shapes when expanding clipped groups.
- Fixed a bug in using the gradient popup view when editing the gradient.
- Allow color picker use from the gradient popup views.
- Show integer numbers with no decimals in the UI.
- Separate default brush width from stroke width.
- Added a brush size option to the context panel for the symbol set adjustment tools.
- Fixed a bug in using width profile in image based brushes.
- Fixed a bug expanding image based brushes.
- Improved support for the wintab driver with non-Wacom tablet.
- Show correct paper size with the Windows printer drivers.
Default Brush size is much better now
So much progress per update and already see a lot of things I need to try/recheck. It's nice to see that our bug reports matter. You're doing a really good job here, @VectorStyler (as always)
