Just a Pattern
created a, color-wise, somewhat structured version.
A fairly simple pattern, what made it special was
the use of βcolorizeβ with my own palette.
Menu > Effects > Replace colors > Colorize...
another one of my pattern experiments
also colored via colorize like the one above
Working on a Mosaic Project, reusing an old pattern i made,
here a Result. Everything made in VectorStyler. To get slightly
different colors for each mosaic tile "Disturb Colors" was used.
Menu > Effects > Replace Colors > Disturb Colors
played with randomness
Was playing with randomize in the Repeater using just a quad.
Did a Boolean "Dividide" with the Result, then a "Offset Path" Shape Effect
" Inner Offset" and at least i use "Colorize" with a Color Palette i made.
Someone said the previous picture looked like a collection
of Polaroid photos, so I made a version like that too.
This was made with the help of Actions (Vectorstyler Macros)
to get the Polaroid look.
Continued a bit with my mosaic project.
I had the idea of ββa kind of natural looking color gradient for mosaics.
The "Color Disturb" function was no help because of the gradient required.Instead, I created a duplicate version, colored it using "Colorize"
using my palette and made it transparent (20%). I placed it over
the gradient, which creates nice, slightly differently colored tiles.
@Subpath said in Just a Pattern:
Another pattern, created in Vectorstyler
is an overlay of different patterns and
experiments with combined stroke stripes
This one looks truly elegant and aesthetically pleasing.
thank you, i like that too.
Been playing around with some lines/paths
and decided to try a mosaic with them.Made two paths and a blend between them
the deformation was made in CorelDraw because
they look better, but VectorStyler wants to improve
the deformation toolsThe rest are made in VectorStyler.
These are three times the same paths/shapes (layered)
one for the fill, one for the mosaic and one for the transparent
and randomly colored mosaic to give it a little more life
While browsing through old things I've made, I found this
variation of the blue floral pattern I posted above.
and randomly colored mosaic to give it a little more lifeInteresting pattern - it reminds me of a cobbled pavement. In this case "the stones" shouldn't overlap
 - example
Thanks, you're actually on the right track
The pattern you mentioned is one of several experiments that
should ultimately led to something like a cobblestone/mosaic.My goal was to figure out a way how to create something like
that in Vectorstyler. I'm still experimenting a bit, but when
everything will fall together, I'll post a tutorial.
@Li-Xiao created a few designs in this thread
https://www.vectorstyler.com/forum/topic/5140/patterns-generated-with-node-bump-effectI couldn't resist taking one and trying out Colorize.
Here the needed StepsSelect the Design
Expand Appearence
Ungroup the DesignDo a Boolean Divide
Fill the Result, color doesnt matter
(colorize work on filled objects only)Call Colorize
Call Colorize Options
deselect "Change Strokes"Choose a Palette/or some Colors
( you can create your own Palette
or select some colors using the
system palette )
You could also color only the Strokes if you like.
Here another one
@Subpath Very beautiful
  , I also really enjoy using Colorize.
Metaball try made in VectorStyler
@Subpath Cool !
@Devil-Dinosaur, thank you
Indeed.
Will do a little Tutorial and show a few Tricks.
Some optical illusion, i made a while ago.
The base was simple a yellow stroke where i place a pattern Brush
in the same size above and the copy scale and rotate it.Here the Base
Here the Pattern
Another interesting optical illusion.
Made in VectorStyler and Black InkVectorStyler
Dashed Lines, random colorized, the whole thing copied, and
two copies placed underneath, each with a Gaussian blur image effectBlack Ink
Only for Symmetry, because of its symmetry Fusion Feature.
