update 1.2.073
VectorStyler 1.2.073 release notes
- Allow blending solid colors with gradients in the blend effect.
 - Fixed a bug in copying gradient fills through clipboard to other applications.
 - Drawing new ellipses should start with default options.
 - Disable corner options if ellipse is not an arc.
 - Fixed a bug in ungrouping transformed reference shapes.
 - Allow direct preview editing in wireframe mode also.
 - Added a new action to select objects with the same name (Select By Style -> Object Name).
 - Improved transform each mode for scaling.
 - Selecting parent when node is selected should select the object.
 - Allow content scaling in circular repeater.
 - Improved AI file format compatibility for gradients.
 - Allow center change in the Node Bump effect.
 - Fixed the randomized mode of the Node Bump effect.
 - Move curve segment when end nodes are selected.
 - Fixed a bug in the extend path tool when working with paths with rounded corner.
@VectorStyler said in update 1.2.073:
Fixed, thx.
Fixed, thx.
Works great, thx!
