Where to disable the Selection Frame which follows the Shape form ?
Would like to disable the Selection Frame which follows the Shape form.
Because it make its hard to see the colors when colorize.Need a tip where could do that. My guess is Settings > Indicator Styles
but i dont know exactly which one.
Here's an image: The selection frame the arrow points to can stay.
But the others should be deactivated.
@Subpath Not possible to disable if the object is selected (can be hidden when moving, but it will show when in modal views)
But you can select the object and switch to some other tool (maybe a style picker), and then the selection frame is not shown
As an alternative to disable it.
Is it possible to change the color of these blue selection frames, for example to white?I took another picture just to make sure what I mean
@Subpath in Settings -> Indicator Styles -> Selection Outline (the Selection Indicators group)
Thank you
