Flip Rulers
Rulers appear to measure with the old PostScript measurement system (Bottom Left is Zero, Top Left is Zero) ala Aldus Freehand vs old Adobe Illustrator 1.1 - not sure the true naming convention. However many (most?) other layout / design apps the "norm"? seems to be to measure XY from the Top/Left. Positioning elements with this previous mindset makes work counter intuitive (to me at least) - is there a way to change the Zero point to reset the rulers somehow?
The ruler origin cannot be changed (added this to the bug list)
The coordinate direction can be changed with Document Setup -> General (tab) -> Top-Down Coordinates.
Ruler origin support has been added:
- on top-down coordinates the ruler origin is at the top-left corner of the default artboard size (will not move if the artboard is later edited).
- ruler origin can be moved interactively by Option+press the mouse in the ruler corner and drag to the document area.
- ruler origin can also be set in the Document Setup -> General tab Origin X/Y fields.
- ruler number signs also follow the top-down option.
@vectoradmin this is looking good!
In beta 159, setting the transform origin for an element to top left - then positioning the element to 0, 0 in transform results in Y coordinate using the height of the artboard. This incorrectly positions the element off the artboard.
Did replicate this, it is a bug. Fix will be in the next release.
build 160 fixes this, and several other issues regarding the ruler and coordinate system direction.
