Transform pivot point regression
When I set the transform pivot point for a full 360 degree rotation and try to duplicate copies using Shift+Alt keys, VS is failing to follow the desired set rotation.
@William-Kansepa A recording is needed for this one. Did you rotate with the Transform panel, or with the transform tool?
@VectorStyler said in Transform pivot point regression:
I used the Transform toòl and Control+D.
This issue has been resolved in the latest update. Thank you!
