Support a Blob type of vector brush
@Subpath thanks for these tips.
Yes, I've tried to change the shape of some tools like the "Shaped Bump Tool" but did not find it to work as expected. Maybe I missed how to use it properly.
Coming back to the Path Brush tool, I really like what can be obtained with it, to imprint some patterns on the surface of shapes.
I experimented a bit and tried some modifier keys with it. I was hoping Alt would turn it into a Path Eraser but it doesn't.
However, a cool modifier is Shift, where if you shift-click with Path brush tool on a shape (doesn't have to have a shape role), the nib takes that shape. You can repeat over and over and get some kind of fractal construction where the path embeds smaller versions of itself.
here is an example : https://somup.com/cTQFl7P10Y
@VectorStyler said in Support a Blob type of vector brush:
@Subpath said in Support a Blob type of vector brush:
When painting with the brush (not clicking) the top is always rounded.
Only when clicking you can use the selected shapeIs there a reason you don’t want to have it operate in that manner? From my perspective, I would find that option very useful. A lot of interesting things could be done if the painting aspect used the shape and was not just the default rounded.
@Boldline said in Support a Blob type of vector brush:
When paining with the path brush, an expanded outline shape is created (calligraphy and variable width included).
But there is no method to using an arbitrary shape in this process. It is just no way to "define" it, unless I do some hacking.
@VectorStyler It's not the way it's working today but I agree with @Boldline it would be great to be able to "paint" with a shape
The way I imagine it is you drag the mouse and VS inserts+merges shapes continuously (at intervals), like if you were clicking after each small position offset
like this : https://somup.com/cTQF2FP1a9
I don't think any user here would want to pressure you into any kind
of hacking. Is just we don't know in full the mechanism behind.As for me, I can live with the current situation. Once I know how
something works, i have no problem to act accordingly.
... However, a cool modifier is Shift, where if you shift-click with Path brush tool on a shape (doesn't have to have a shape role), the nib takes that shape. You can repeat over and over and get some kind of fractal construction where the path embeds smaller versions of itself ....
Interesting, did not know that.
Put a video together to better show the 3 main problems with this software still
https://youtu.be/Pb7otS5bovUIt's definitely close but right now not quite where it needs to be.
@Bitten What kind of tablet is used there?
@VectorStyler Wacom Movink 13
@Bitten said in Support a Blob type of vector brush:
I will try to fix these issues as soon as possible.
@VectorStyler Legendary! If you can get these issues fixed I can finally after 10 years of waiting graduate to a modern graphics software.
@Bitten The tablet support on Windows has been somewhat difficult.
@VectorStyler I found the tablet support working quite well on MacOS. The pen "nib" blue overlay stays at contant size, but the drawing follows pressure quite accurately and in real time, which is very usable.
Here with an ipad and Apple pencil used in sidecar mode : https://somup.com/cTQqlTPjuN
@VectorStyler Understood, if there's anything you need me to help with re: testing potential fixes etc. just let me know
I'm trying to replicate these issues with a Wacom Intuos tablet.
I have problems with replicating the pinch zoom issue.Is the "Use Windows Ink" enabled for you?
Also: did you enable (or disable) the "Use Tablet Driver" in VectorStyler Settings -> Application section?
@Bitten I added some fixes to the tablet handling:
- brush should preview width by default
 - clicking on tools should work with the tablet
But I could not replicate the multitouch pinch issue
