Gradient panel and color panel sync issues
I was about to request that when ie the stroke is active (in front) in the color panel and the gradient tool is activated, the stroke should be pre-selected in the gradient panel. It looks like that is intended in your code I now see. However, in this file at least - strange things happen. And in the end even more strange things happen.
Pssst: This is still the file you investigated yesterday. I ungrouped the layer with the stroke and the path with the fill below, it became the object / slice of bread with a correct stroke and fill. Visually at least, the data could be "challenged" of course.
Another observation:
- Expand stroke results in a significantly darker gradient
@Ingolf Bugs that I found:
- the expand stroke result is not the same (gradient is not shown correctly when it is a stroke).
- both the panel and the gradient editor are not fully updated when changing between fill / stroke.
- the editor is changing the stroke even if the fill is selected.
I added these to the backlog, am I missing something?
@vectoradmin said in Gradient panel and color panel sync issues:
That should cover my observations, yes, thanks!
@Ingolf This problem should be fixed in build 1.1.024
