Clipped blend lines disappearing
I have pasted a blend pattern inside a shape and challenges arise when trying to remove the stroke from the shape. The moment I try to remove the stroke, the blend pattern also gets affected. All the strokes (i.e. on the clipping container and the blend) disappear.
Refer to attached images.
@William-Kansepa This can be replicated. But a Command+R (refresh) can fix it.
@vectoradmin said in Clipped blend lines disappearing:
Thank you so much. All the same I hope that this behaviour will be fixed in the future.
@William-Kansepa This issue should be fixed in the new build 1.1.002 (beta)
