The ability to drag the eyedropper around the palette
Feature: The ability to drag the eyedropper around the palette, rather than having to click each time..
Reason: It'll make it easier to select small variations in color.
Yes, this could be added. Have to check if there is a conflict with other features.
Palette panel: currently dragging a palette color will initiate drag&drop, that can be used to style objects, or to create presets or color styles.Edit: if this refers to the Color panel spectrum, then yes, it is an easy addition.
beta 29: added dragging support in Color panel color selection from spectrum image.
Confirmed! This feature is added!
