New From Clipboard
Seems like the "New From Clipboard" command would create a new document that has the max dimensions based on the size and resolution of the current clipboard contents. Currently it seems to use the size of the document from where the original clipboard contents came.
@badcat Added this to the backlog.
The new from clipboard issue is fixed in build 200
@vectoradmin Yup this works
  Would suggest to compensate for Stroke, Brushes, effects etc. -- otherwise great!
@badcat Yes, that can be added.
