Can Scaling stokes and effects be on by default? Can we make it easier to switch all child sublayers by editing the setting at the parent level?
@Boldline There is also a "Transformed Stroke" option in Document Setup. This will affect newly created objects.
As i only play with graphics and try out the ideas that go around in my head.
( Dont work no longer as a professional )
For this i use the programs that have the tools that can help me with the realization.
.Short note and praise for VS:
Since VS has so many useful and interesting tools by the way, I try most ideas in VS
since I bought a copy. (I think that says a lot)
.I don't really have a need for scaled strokes if I need it,
I just set a different stroke widthIf I really need it I would try to copy my design into AD, CDR or Magic Graphics Designer
and get it done there. (or maybe solve it via the outline effects ?).@Boldline
...I'd be interested to hear what you feel would improve it and make it more of a seamless process...As i dont really know the Concept behind it, why it should or must work this way
(never saw something like this before)
i can not say how to streamline it
( toggle could be a first start ? )
@Subpath said in Can Scaling stokes and effects be on by default? Can we make it easier to switch all child sublayers by editing the setting at the parent level?:
I just set a different stroke widthMaybe we are thinking of two different things? I'm talking about designing something at one size and then needing to group it and scale it up - the entire design element with fills and strokes included and wanting them to all stay relative in size to one another in the process.
@Boldline said in Can Scaling stokes and effects be on by default? Can we make it easier to switch all child sublayers by editing the setting at the parent level?:
well, dont think that we talk about different things. That you like to scale your entire design elements
in relative in size to one another, is very clear to me.
But i cant help you out in this case.
Edited:
(well you mentioned yet effect scaling and i wrote only about stroke scaling )i just wrote that i am not in need of this kind of scaling in VS and i dont like
to used it in VS. So if i need some different stroke width
i just set it.
@b77 said in Can Scaling stokes and effects be on by default? Can we make it easier to switch all child sublayers by editing the setting at the parent level?:
A sticky button would be really handy for this as 90% of the time I need strokes to scale
@Dazmondo When creating new documents, enable the "Transformed Stroke" option in the Document Setup -> General view.
Doesn't work for me - the strokes only scale when grouped ????? or if scale image filters is ticked
@VectorStyler It looks like it doesn't work for parametric shapes (smart shapes). Easily fixable, I guess.
@Dazmondo Convert them to curves and this works as expected.
@Dazmondo Yes, a few parametric shapes are not "scaled" (rectangle, ellipse).
An other way to go around this is to disable the Direct Shape Transformation option in Preferences -> Editing Options 2 (bottom-right corner).
An other way to go around this is to disable the Direct Shape Transformation option in Preferences -> Editing Options 2 (bottom-right corner).Done and working ----
