Transparency via keyboard does not work (Windows .057)
I've seen this work once today, but not otherwise.
I can't select an object on the canvas, and type 50 or 050 for 50% transparency. Nothing happens.
@Ingolf tested on my M1 Mac and works fine here
Strange shit. I purged the entire user folder and restored just the license file, but still nothing.
Allright thanks, I'll see later on my Mac and Windows 11 machine.
It doesn't work on my two Windows machines, one with Windows 10, the other with Windows 11.
On the first (Windows 10)
- I closed VS
 - Deleted (moved) C:\Users<username>\NumericPath
 - Restarted VS which now lacked license
 - Closed VS
 - Copied license.xml back to C:\Users<username>\NumericPath\vectorstyler1.0\vector\
 - Started VS and was now in default config
Still not working. I would think that all custom config is taken out of the equation now.
It doesn't work on my Windows 11 machine either. Both machines have one thing in common and that is that they use external wireless keyboard with USB receiver. But it doesn't work on numeric keys or regular keys.
It still works perfectly on my Mac.
@Ingolf said in Transparency via keyboard does not work (Windows .057):
Does not work for the numeric keys on the right. Seems to be a bug.
@Ingolf This issue should be fixed in build 1.1.062
@VectorStyler There is still some issue when I click:
1-- transparency it set = 11
2 -- transparency it set = 22
3-- transparency it set = 33
0-- transparency it set = 100 and so on.
when click two number:
11-- transparency it set = 10
23 -- transparency it set = 30 ( it takes the last digit and add suffix zero to it)
@Jayanta-Das said in Transparency via keyboard does not work (Windows .057):
23 -- transparency it set = 30 ( it takes the last digit and add suffix zero to it)I keep this issue open.
@VectorStyler This issue should be fixed in build 1.1.072
@VectorStyler said in Transparency via keyboard does not work (Windows .057):
Yes, VS responds correctly to keyboard input now (tested on Windows 10 laptop) but the parser does not allow 0% - not even when 000 is entered.
