Bugs - cros hair cursor v. .64
Any improvement if you disable "Show position in Ruler?"
I tried enabling both on an old Windows machine and the position indicator in the ruler lagged behind the crosshair cursor.
@b77 yes, the entire left menu disappears and software is frousen
in version 1.1.0.62 it was all eye on version .64-bug (pc version)
I can record a video
@poljand I tried to replicate this on Windows but it seems to be working correctly here.
Two things to try
first remove the VectorStyler user data folder (when VS is not running), by remove the c:\Users\<username>\NumericPath\VectorStyler1.0 folder.
the second thing to try is to uninstall and download VS again (there were some late changes to the update).
If this occurs after the above steps, try the Panels -> Toolbox menu to show the toolbox, and check if the freeze occurs again.
I will open a bug here and try to replicate the issue.
@poljand One question, is this on Windows 11 or 10?
@VectorStyler win 10
@VectorStyler said in Bugs - cros hair cursor v. .64:
Two things to try
first remove the VectorStyler user data folder (when VS is not running), by remove the c:\Users<username>\NumericPath\VectorStyler1.0 folder.
I will open a bug here and try to replicate the issue.I am checking, I will write what I have done in a moment
success, after deleting all files from
 \ Users \ <username> \ NumericPath \ VectorStyler1.0 folder
and after reinstalling version 1.1.0.64 EVERYTHING IS OK.poljand
