Gradient Mask Effect fails to transform
Thank you for the latest update (VS 1.1.073) @VectorStyler.
I however have encountered a worrisome behaviour in regards to the Gradient Mask. The Gradient Mask Effect's position remains anchored when transforming artwork using rotate, skew or reflect. The artwork will transform but the effect will not budge.Is this the new dispensation or it is a bug?
@William-Kansepa In Transparency panel menu: enable the Transform Mask Content, while the object is selected.
Thank you @Vectorstyler.
It worked, but I would prefer that Transform Mask Content be enabled by default. I think it would be more efficient that way. I feel it's an awful bore to have to revert to the Transparency Panel Menu each time I need to make a transformation. All the same I also would like to tap into other users input. I very much would want to hear their thoughts on this one.
