Resize via panel not refreshing
Resizing (say) a rectangle, manually using the handles, it refreshes OK, resizing via the panel editfield doesn't immediately refresh the visible object (although the actual size is correct). If you resize then pan the screen, it refreshes. I don't recollect this being an issue in previous releases ??
@Igull Yes, this has been reported before by others also, and I could not replicate it.
The bug is still open.
@Igull Can you confirm that the issue happens only after working on the file for a while — like some action or command breaks the direct refresh?
@Igull Another thing to check: what happens with changes from other panels? are those refreshed correctly?
@b77 said in Resize via panel not refreshing:
No, I can create a new file and it happens (I may have other files open at the same time 'tho).
@VectorStyler said in Resize via panel not refreshing:
OK, I have the transform panel permanently on show and that's the one I always use to resize. However, if I use the Shape panel to resize, there is no refresh issue.
One thing of note, if resizing using the Transform panel, the Shape panel does not update the axis I just changed (but the Transform panel does vice versa)
Having just played with it, I'm getting strange interactions - occasionally, the completely incorrect size is shown on the shape panel to the shown graphic.
I'm using a rectangle for these tests.
@Igull I will try to replicate this.
This is still a serious (maybe not serious, more just really annoying
) ongoing issue for me, I've attached a vid from v080 ...The rectangle isn't refreshing after resizing via the transform panel (it DOES refresh after resizing via the Shape panel however) - also, there is an issue with line width, the verticals/horizontals are different thicknesses after resizing (the rectangle).
TIA
@Igull I keep this issue open and will find a solution somehow.
