Bug in 1.1.077 - Snapping icon is always inactive
Wondered why snapping occured when snapping was disabled. The toolbar icon doesn't change when I click it, but snapping does turn on and off.
@Ingolf Cannot replicate it here.
Do you mean the blue highlight doesn't go away when you click the button?
@b77 said in Bug in 1.1.077 - Snapping icon is always inactive:
Do you mean the blue highlight doesn't go away when you click the button?Opposite - never blue
@Ingolf I tried to replicate this on Mac, but here it seems to be working.
Is this on Windows or Mac?
Maybe it has to do with some settings.
@VectorStyler said in Bug in 1.1.077 - Snapping icon is always inactive:
Maybe it has to do with some settings.Mac, I'll mail you my settings
@Ingolf said in Bug in 1.1.077 - Snapping icon is always inactive:
@VectorStyler forgot where settings are saved on Mac?
@Ingolf They are here: ~/Library/Application Support/NumericPath/VectorStyler1.0/vector/data/resources
Finder > Go > Go to Folder can be used to get there.
Thanks, buddy!
@Ingolf Replicated with the settings / workspace file. I'll find out what is going on.
@Ingolf The fix for this problem will be in the next build.
Meanwhile, as a workaround: uncheck the "Active Item" checkbox for the folder containing the enable action (in the context panel customization).
Meanwhile, as a workaround: uncheck the "Active Item" checkbox for the folder containing the enable action (in the context panel customization).Thanks, that worked!
