The units in the Transform panel change according to position
I can't yet figure out how it happens , but often the Height units in the panel change from mm to metres. Annoying. I don't change the position/size of the panel, but I have accidentally observed that in this situation the change also happens. Maybe this has something to do with it.
@encart I guess it happens after you delete just part of 'mm' (plus the number), so the app is left (or stuck) with 'm' to use instead?
