Non modal Panels ?
I'm sure you already have a long backlog list.
But I am missing non-modal panels in some cases.Are non-modal panels planned?
I miss something like that at the moment especially
for the Transpose panel ( Object > Transpose > Transpose )
and also for the Colorize panel.Especially with the random function I would find it less work
if you had the possibility to select objects directlyAt the moment you select your objects, set your values
using the random function confirm it and the panel closes.Selects another number of objects calls the panel and so on.
Would be a lot easier if the transpose, colorize panel could stay open
@Subpath In some cases this might be possible to implement.
The problem is that interacting with the document while also in such a panel, might create additional problems.
Have to check this on a case by case basis.
@VectorStyler said in Non modal Panels ?:
i would consider this as a long term thing
even though I find this very useful
and I guess that it also affects only a few panels
Edited:
One more thought came to mind.
If we had a scripting language in VS, these things
could perhaps be solved in this way.
