Copy and paste problem
Copy and paste problem here.
VS works only at the second try
this is always happen after the first/fresh start
of Vectorstylerother programs work fine
@Subpath I will try to replicate this.
I have the same problem.
I'm not having that problem currently, but there have been times I've copied and pasted and dragged it and it does not act as expected. There are a few other quirks like that in Vs that occur but it's hard to report or replicate or have something tangible to send to @VectorStyler
@Subpath said in Copy and paste problem:
Yes, I get the same issue regularly - the problem I find is generally when hitting cmd+c from another file and then cmd+v into the current file, the paste buffer doesn't contain any data - it's very inconsistent. However, I've found that if you use the menu copy command, it seems to work all the time (maybe
).Neil
@Igull said in Copy and paste problem:
nope,
menu copy works also only on the second attemp
tried all variants alreadyafter that second attemp everthing works as usual
also in long sessions
@Subpath Can be replicated here also on Windows (not on Mac).
@Subpath This issue should be fixed in build 1.1.080
@VectorStyler said in Copy and paste problem:
Yes, seems to be fixed now, thanks.
yes, is fine now
