Window Tab Arranging
Seems that the ability to re-arrange open file window tabs has broken - on Mac at least ?
Tell me it's not a pref
@Igull Not it is not a preference.
Can you detach a document by dragging from the tab?
@VectorStyler said in Window Tab Arranging:
Can you detach a document by dragging from the tab?No.
@Igull Something is broken in the VS settings / workspace there. Try backing up the settings.xml and workspace.xml files are remove them (with VS not running).
Can you detach a document by dragging from the tab?Never used this so no idea how it worked or how to use it, but I see the same behaviour that @Igull does.
However, I can drag the tab to the bottom of the screen or over layers docked on the side and then it is detatched.
View -> Arrange Views -> Collected to attacht the document to the main window againSo the issue must be that if the document is released above itself, it is not detached.
@Ingolf said in Window Tab Arranging:
This one was the same before, it is docked in the group. But it should change the position of the tab, relative to the others
Yes, broken prefs setting.
I keep my prefs files just in case I need to revert back - I've tracked it down to where it happened and have both files (before and after it broke) if that's of any help in debugging the issue ? It actually happened back in v079 - don't know why I haven't noticed it since then :-))
@Igull Please send me the settings and workspace xml files by email. I always have the default and I cannot replicate here.
Just sent.
@Igull The "Lock All Panels" option is enabled, and this will also block docking of the document views.
Yes, I do that so I don't tear of my nicely organised panel interface
Should this option lock the document positions too ?? You would want to lock your interface certainly, but I would be inclined to leave the document positions alone - depends on how the rest think ???
Thanks for finding the cause
