Left and Right ALT keys are not mapped the same? (1.1.084 Win 11)
@Victor-Vector I checked this and currently the Right-Alt key is blocked as there were some issues reported earlier with it.
I think it is also used for some special character input with some keyboard layouts.
I will find a solution for this problem.
@VectorStyler I appreciate you looking into this and I hope you can get it working. Thank you!
@Victor-Vector said in Left and Right ALT keys are not mapped the same? (1.1.084 Win 11):
it is easy to get it working (just flip a flag) but the problem is that it caused some issues as a keyboard modifier while using the mouse.
@VectorStyler I'm not that familiar with Windows, so maybe it's not a good or doable idea… but:
If Victor is left-handed, maybe a setting to switch this for left-handed users (disable the left Alt and
enable the right Alt) could be something useful.
@b77 Haha, you nailed it. I am left handed and the right ALT is my "primary" ALT, because I got into an early habit of using my mouse in the left hand.
Any accommodations are appreciated, but I have spent a lifetime adapting
As I wrote before, the ALT GR key is used at the German keyboard
for certain special characters. The most important is the @ character
for email addresses.Instead of the ALT GR key on the right side, I can always use the ALT+STRG (CTRL) keys
on the left side instead. Since the ALT GR key only puts these two keys together in one.By the way, I don't know any shortcut in VS where I need the ALT GR key.
If then only sometimes in texts for special characters (where it could be replaced
by ALT+STRG (CTRL) ).Here a Wikipedia article about international keyboard layouts.
https://en.wikipedia.org/wiki/AltGr_key
A couple more pieces of data:
Other commands are not left or right ALT specific.
For example to "Create a Copy of the Dragged Object", I can hold down either ALT key and drag, and it will copy the shape.
I noticed that in Preferences > Modifier Keys > Create a Copy of the Dragged Object is set to ALT by default and
Preferences > Modifier Keys > Create Composite Shape with Boolean Operation is set to ALT by default.
I tested this in 1.1.086 and it seems to work!
Thank you for fixing this issue
I am experiencing a regression and I think it may be related to this change.
To create a diacritical mark I currently have to hold AltGR and press the letter twice.I have noticed that pressing this key while entering text, changes the tool to Transform Tool, as it does when I press Ctrl.
@encart Yes, this is a regression.
