Old problem with long paths is back in 1.2
Drawing long paths with pencil or brush tool is causing a line to "wiggle." - Record it
I mentioned this problem in this thread before.
@Harry I think the issue you are seeing is the same one that I mentioned in this post here a little earlier today.
@VectorStyler had responded that it was meant as an improvement to adjust the earlier placed section of the line or path result based on the way the more recent final line section was created.
I can appreciate the desire for the line to be improved, but the result is not where it needs to be yet. I'm going to post more about this topic when i get the chance hopefully later today
@Harry yes, it was changed recently, will return to the previous mode.
@VectorStyler one of the things I like about the new version is that when erasing, if I hold down the eraser or path brush, it gives me a near straight line erase.... this is a good thing as a secondary option in my opinion.
@VectorStyler is it worth keeping your overall mode as an option?
@Boldline said in Old problem with long paths is back in 1.2:
I think it might be. In some cases it could be important to see the precise shape of the erased area. Same goes for the path brush.
