Impossible to give a stroke value to blended objects
In all my test files, none of the objects resulting from shape blending are visible. I only have the original objects before blending. More precisely, the strokes are no longer visible. The thickness is set to "none" and it is no longer possible to assign a value to them.
Edit: also an issue with v. 1.1
@Pat Cannot replicate this here. A short screen recording might help.
Also: try resetting the app to defaults before trying again.
@Pat I tested with a few files containing blends and this seems to be working here.
Send me a file which has the issue.
@Pat
works here too, latest beta
@VectorStyler said in Impossible to give a stroke value to blended objects:
@Pat Send me a file which has the issue.
@VectorStyler file sent
@Pat Yes, there seems to be a regression with stroke styles containing some extra attributes (profiles, dashes, etc).
@VectorStyler The bug is fixed... Thanks for this rapid update & fix
