update 1.2.005
VectorStyler 1.2.005 release notes
- Improved the data sources panel (1.2).
- Restored node size in settings.
- Set text color when setting color for a selected text frame.
- General stability improvements.
- Fixed bug in duplicating multiple text frames.
- Expanding bristle brush on certain curves.
- Fixed bug in bristle using width profiles.
- Improved path offsetting and stroke profile handling.
- Fixed bug in outline zigzag effect on complex shapes.
- Blending and contour of stroke cap shapes.
- Artboard label settings to be used on artboards.
- Added a preview button to the create guidelines view.
- Text baseline path should not extend beyond text.
- Better tracking handling with text on path.
- Creating text on path with selected shape to position the path correctly.
- Show correct font when a new paragraph text is selected.
- Updating selection presets to capture selection correctly.
- Number fields in text formatting options to use the font size units.
- Selecting text should work between multiple linked frames.
- Do not add extra leading before the first line.
- Fixed bug when exporting to PDF with certain fonts (SF Pro).
- Fixed a bug in adding large corner to rectangles.
- Fixed a bug when rearranging artboards in the canvas panel.
- Allow corner shape preset and style creation from composite and closed shapes also.
- Show outline while hovering with the node tool for parametric shapes also.
- Show text cursor when creating an empty text frame.
- Document save indicator to update when opening a document.
- Fixed a bug with the select shape and link shape commands.
- Fixed a regression in using host system hyphenation options.
- Hyphenated works should highlight correctly.
- Allow exit from isolated mode with the node tool also.
- Deleting nodes around straight lines should keep lines straight.
- Fixed a possible crash when using style and symbols links.
- Keep the correct position when creating reference form an object.
- Do not change symbols with color filters (requires expansion first).
- Fixed a bug with the small caps (and petite caps feature.
- Allow width profile node deletion in the modal view also.
@VectorStyler said in update 1.2.005:
@VectorStyler & with "All artboards on canvas"
Very helpful, thanks
... and of course for all great improvements
