Affinity Designer vs VectorStyler
  • @debraspicher said in Affinity Designer vs VectorStyler:
    @Ingolf I suspect, at least in part, one reason Affinity performs so well is that the rendering to the display is not forced to be accurate. In too many instances I've had to recheck my source or export for even very small images because my viewport is blurrier even if I open the file straight from the OS, with no changes (yet). Yes, even at 100%.
    Other programs may be slower, but at least I can fully trust what their engine shows on my display and it is consistent.
    Adobe Illustrator's rendering is accurate with a very good performance, although no vector graphics software has beaten Macromedia Freehand's performance yet.
    Oh. Not a problem in my work, never battled with that issue.
  • @gotanidea said in Affinity Designer vs VectorStyler:
    Not my experience but my stuff if seriously complex. Importing it into Illustrator never was an impressive experience.
    But I do appriciate if the rendering can be configured to be extremely accurate or not because I don't need it that much during the many, many hours of working, zooming, panning, adjusting. I need a responsive and ultrafast update.
  • @Ingolf said in Affinity Designer vs VectorStyler:
    Let me explain for the record. I get the feeling this thread will age very well.
    For my case, it's less important that the viewport is incredibly accurate for vectors while working, but when I check the work, I have to have the control to see the accurate result should I need to. Some of that is down to adding my personal touch to curves but also technical requirements (pixel-hinting smaller graphics).
    There is a long-standing bug that affects my setup where AD will show "Pixel Mode" as a 200% view if I have a DPI scale =>150%. I must use Retena because it will show the proper view, but then also trust a new bug won't appear in its place, so I just altered my DPI scale OS-wide at a smaller scale to compensate. I'd run into so many bugs using Affinity software that I basically don't trust their products anymore for anything mission critical.
    For Photo, I guess because the design of Layers are vector-based, they also may not display accurately during viewport fits in Windows. It's so subtle it can look like the image is of lesser quality or is compressed, but it's detrimental to understanding what will happen with the end result clarity-wise (especially with any filters). Photo's viewport is very unreliable for me. When this happens, I can be overworking an image without realizing it or missing details I could have worked with sooner to come out with a better final product."
    Edit: Anyway, I don't intend to beat any drums. I do want to share details like this because it better illuminates on my own use case.
  • I completely agree. I'm just advocating for understanding how good, good performance is, and it's probably hard to compare programs that are structured differently.
    What I really appreciate about Affinity is that it delivers superb performance and fundamentally renders what I draw in very, very high quality and updates instantly. I NEVER have pixel view turned on, and I use view without FX to give the computer a break more than to get better performance. That’s how quickly Affinity draws the user interface on my M1 and M2 Mac. And even on older Windows machines.
    So, it's utterly surreal when I move the illustration over to other programs as pure vector, and these programs struggle to render it in something that can be remotely compared to Affinity.
    I'm not looking for programs that continuously optimize one function or another to draw a bit faster, but fundamentally can display and update my work quickly in high quality. While I work, they may well cheat a bit with visual tricks, because I can't use anything that involves a total recalculation of everything I see every time I zoom or change something. If I have a HQ rendering option too, I'm good to go.
    The classic preferences for rendering quality that no one understands, which are also in VS, are not understood or used by the average users. There is probably more need for Draft, Normal, and High Quality versions, where only draft is visibly worse.
    But long story short, performance is important for us who do complex things, and for me to work meaningfully and see how it roughly ends up, it needs to be fast and look reasonably final. Affinity has shown that it's possible to come close with really good performance.
  • @fde101 said in Affinity Designer vs VectorStyler:
    AD also has an entire company behind it (maybe two now?) where VS is a single developer. If someone at Serif gets hit by a car and dies today, there are others who can take their place, and the show can go on - is there a continuity plan in place for VS?
    I would also really like to get an answer or at least a comment on this question before I can seriously start investing time and energy into learning VectorStyler and making it a tool of choice. Is there a contingency plan in place for VectorStyler that at this point is being developed by a single developer?
    @JuurGroove said in Affinity Designer vs VectorStyler:
    There are many single developer projects out there (including closed source), that worked out just fine without this kind of "official" contingency plan, that is all I can say.
  • @VectorStyler Honestly, that "worked out just fine" doesn’t instill too much confidence for the long term. But what I have seen so far plus the ongoing sale have convinced me enough for the time being. Thanks!
  • @JuurGroove said in Affinity Designer vs VectorStyler:
    You're absolutely right in your concern, and it is indeed a cardinal consideration when making acquisitions in a company. For some businesses or individuals, continuity in data formats, workflows between programs, and training (which creates the velocity that drives profitability or efficiency) is absolutely critical and non-negotiable.
    For others, it's a balancing act involving many factors. It dawned on me as I reflected on this just how many programs I've seen terminated in the last 10 years due to market-driven acquisitions: acquisitions followed by program shutdowns (algorithm purchases or hostile takeovers), portfolio reductions to cut costs, consolidation of programs and services for the same reasons, and finally, simply programs that no longer delivered the desired return or lost out to competitors. I've also experienced cases where one-person projects or small companies suddenly disappeared without further explanation. My point is that the market is dynamic and unpredictable, with shorter and shorter intervals between products being discontinued without more than a few months notice.
    Additionally, there are many other risks — such as the workload becoming too overwhelming to maintain, which can impact both stability and the release of new features, leaving users feeling neglected for years.
    So far, errors are being impressively fixed in VectorStyler, whereas the above issues have plagued Affinity users for a decade. As an Adobe customer, you get much more, albeit at a significantly higher price.
    If you're vulnerable, you might want to spread your risk a bit. Otherwise, betting on Adobe, which is likely to stick around for a while longer, might be a safer choice. 🙂
  • If you already have some momentum with Affinity Designer, you’ll probably be fine sticking with it (the Canva connection might not be as disruptive as it seems). However, VectorStyler is worth a look if you’re after advanced vector tools and a smaller, more responsive community.
  • I'd like to add my two pennies: While acts of God are always unpredictable, I still think VS ought to be developed by it's present developer. Affinity might have all the resources in the world, but translating that talent pool into BUG FIXES and FEATURES is no easy deal. As they've found out. Bureaucracy sets in. Sign-offs and commercial priorities take over product quality. The list of Affinity bugs spans multiple products, forum pages and years. Some of the most BASIC bugs such as mistranslation in UI haven't been fixed. Vector basics such as curve expansion, contouring, gradient fills, shape-builder, moulding (warping), blending, vector brushes and patterns are either utterly broken or non-existent. Affinity also refuses to output to pure vector. Some times, unpredictably, the lines get rasterized, for no reason. Affinity, STILL, in 2025, cannot save files to a cloud storage or external hard-drive without massively messing up the file. Every new iteration produces more bugs. And those iterations takes months, in plural. And this is the program that's being sold to "professionals". Years of screeching in the forum have yielded no results. I've finally given up. I won't be updating to V3 or even the next versions. It's over.
    VS has struck the golden mean between speed of growth and product focus by creating an feedback loop through this community.
    Other single or two-people project that have done mightily well I can think of: Painstorm Studio & PhotoLine. The latter project has lived for 30 years on the work just 2 people, and an intensely active and knowledegable community.
    Having said that, I think all programs will benefit by being open sourced. I can't elaborate as to why in this message, but I will write a longer post one day.
  • I peak in to see what happens with Affinity but I mainly use it to open legacy documents and maybe a quick export job. I think it's 2.6 now? I'm still on 2.4.2. Little things here and there I might use it for, but I'm always holding my breath when I need to access the Expand Stroke function to do anything. The version I'm currently running is before they "fixed" Expand Stroke to accommodate a new feature set and the algorithmic issues less obvious for that particular audience... but the problems are still there under the hood, the bugs are rampant and some of the regressions, including changes to ES are a problem for those of us with legacy files.
    I don't expect VS to directly compete with Affinity. Feature-wise it's already well-suited for many jobs. It just needs a bit more love when it comes to UX/document creation (especially Windows-related items) and then for me that's replacing a lot of programs that become increasingly annoying to deal with... (such as Adobe...) ...
    Anyway, I don't post as much on the forum, but I email any bugs to the developer. They are very responsive and I always look forward to the new updates/tweaks.
  • In terms of learning, there are a lot of 'AD' video tutorials on YouTube, but almost none video tutorials of 'VS'; So it's difficult for beginners to get started with VS
  • @lilith said in Affinity Designer vs VectorStyler:
    Well, nothing against YouTube videos, VS Vimeo videos have helped me
    in one case or another. I found them quite good in terms of length and
    execution, with a brief explanation of one feature.
    But i think we shouldn't ignore the size of the user base for both
    programs, which is probably one of the reasons why there are more
    videos for Affinity.
    Many YouTube tutorials are also created with the intention of making a
    few bucks, which only makes sense with a sufficiently large audience.
    One shouldn't underestimate the work that a tutorial, a YouTube video,
    requires.
    I also think that potential VS users should watch Illustrator videos
    instead, as many things work similarly.
    Not knowing Illustrator, because I didn't like it (this was before the
    subscription), was my biggest hurdle when getting started. I came from
    Corel Draw.
    So, in my opinion, VectorStyler is more for people who already have
    some advanced knowledge of creating vector graphics.
    Beginners can also easily be referred to the tutorial section here in the forum,
    where they can get a good overview of the options and how to use them.
57 out of 61
