update 1.2.019
VectorStyler 1.2.019 release notes
- General stability improvements.
 - Show document preset groups separately in template list.
 - Contour effect around clipping groups to handle content correctly.
 - Number field scrolling to use rounded numbers in new document view.
 - Intersection mode flipping shortcut to be temporal.
 - Eraser tool improvements.
 - Moving multiple stroke width nodes.
 - Update glyph panel on character selection change.
 - Allow smaller image limit in exporting.
 - Improved support for number variables in repeaters.
 - Improved shape effect support on repeaters.
 - Added a repeater object selection mode that uses background intensity levels.
 - Improved number field input with unit name.
 - Allow selecting fill opacity for text in Appearance panel.
 - Added shortcuts for color and gradient selection.
 - Additional OpenType glyph group support in Glyphs panel.
 - Improved AI file format support.
 - Added a rotate option to polygonal spiral.
 - Improved display resolution support.
 - Highlight current font when using the "All Fonts" collection.
 - Options to preserve color luminosity or other properties in color filters.
 - New actions to restore default shortcuts, menus and toolboxes.
 - Allow applying paragraph preset from the paragraph panel drop down list.
 - Updated Appearance panel documentation.
 - Expanding scatter brush with noise should position objects correctly.
 - Local shape effect on appearance item to work for text shapes also.
 - Improved display of local style effects for text shapes.
 - Fixed several issues with the Guidelines panel.
 - Fixed a bug in the Envelope shape selection.
 - Allow the "Enter" key as a shortcut in the shortcut editor view.
 - Improved display scaling support on Windows (no flickering borders).
Thank you very much!
Thank you so much for all the hard work! I just cleared all my 'unread' posts and returned to find a ton waiting again, all marked as fixes for this release. Exciting to see so much work done, VS is getting better and better!
