update 1.2.020
VectorStyler 1.2.020 release notes
- Added PSD file exporting.
 - Added PDF/X file exporting.
 - Changing font with text containing style links.
 - Blend object with transformed stroke to handle stroke transformations correctly.
 - Improved performance of Knife and Eraser tools with complex paths.
 - Creating adjustment layers did not select image effect options.
 - Selecting image effect asks in modal view should not reset the effect options.
 - Fixed a bug when duplicating text frames inside groups.
 - Creating artboard guidelines for multiple artboards.
 - Symmetrigon side shape selection.
 - Grid repeater rotation to handle backdrop correctly.
 - Additional Layers panel options for simplifying panel content.
 - Fixed a bug in selecting similar stroke styles.
 - Additional spiral shape options.
 - Gradient export to AI compatible PDF files.
 - Improved performance of repeater with blended shapes.
 - Improved simplify path.
 - Added a new action and shortcut to delete segments between selected nodes.
 - Allow node editing of selected but hidden shapes.
 - Improved text on path dragging when moving to another shape.
 - Added Path panel options to set the distance and angle of two selected nodes.
@VectorStyler Great updates! I appreciate it
