(Win beta 1.0.021) Copy Paste Issues
Thanks for the fast feedback and warm welcome.
Yes, I mistakenly wrote Alt+Scroll in my initial message, so I would like to use Ctrl+Scroll.
I mainly use Affinity Designer and Publisher, and I hope to develop a smooth workflow with VectorStyler and the Affinity apps on Windows. Looks like copy / pasting between these apps work on the Mac. Saw that others suggested an even more elaborate compatibility and connectivity with the apps, but for start a simple copy and paste workflow would work.VS would be my main tool for what its name stands for, styling vectors and achieving visual looks that I can't otherwise do in Affinity or other design tools.
@WhiteX Maybe PDF or SVG import/export could help to work around the copy/paste issues. Not as convenient, until the copy/paste issues are fixed.
Yes, fortunately that works well. It'll do it in the meantime.
Any chance to customize the shortcuts in a future release (including the modifier keys)?
@WhiteX Shortcuts can be customized, in the View menu bottom.
About the modifiers: this would be easy to implement (only the UI is missing).
I add this to the backlog, but it will not make it into the next build.
@vectoradmin Awesome, thanks!
@vectoradmin Great work on the new release! I tried to copy / paste into VS from Affinity Designer and vice versa, and still no luck. I'm looking forward to this fix. It'll make my workflow a lot easier
@WhiteX That copy/paste requires EMF/WMF import (and export). That will take some time, but will be in version 1 for Windows.
@vectoradmin Okay, that's cool.
@WhiteX Copy paste has been solved on Windows. Currently only PDF and SVG formats are copied into the clipboard, but WMF or EMF can be pasted.
WMF and EMF are available as import and export formats on both Windows and Mac.If needed, EMF (or WMF) can be enabled as clipboard formats in the future. But I think PDF (and SVG) are much better formats for transferring vectors (both Affinity and Inkscape support these).
@vectoradmin This is great. The default settings are working fine! Thanks a lot!
