Copy/Cut & Paste randomly not working
FWIW, the window is left open from last night's interface glitches, so this may be related to the cursor bug I reported, but I'm not experiencing it atm.
Overall, it's almost like it takes a moment to "go back" into VS with a few clicks to fully get the attention of the application. Sometimes it feels like I'm playing around with the UI in a different instance than the full application so odd behavior occurs or the menus don't trigger immediately (it's like it is lagged...). I would put this in the same bucket with the other odd behavior.
Video with clipboard viewer: https://1drv.ms/v/s!AuWHX0h5bAoRifxdWYZk4GA8xmRcwA?e=bE799q
Yeah, copy and paste isn't working at all now. It won't take images from outside the software and also text. I've had this problem on occasion and often just put it down to a clipboard "compatibility" issue (for example, browser copied transparencies)
More program behavior: https://1drv.ms/v/s!AuWHX0h5bAoRifxfLR-PFdsiB0T2-w?e=XYVGSY
Edit: A restart fixed things.
@debraspicher Go to the settings / workspace file folder with the Help -> Reveal Workspace folder.
Exit VectorStyler and backup / remove the settings and workspace files.
When starting VS it will start with an initial state. Let me know if the issues persist here.
Also, you could send me the backed up workspace / settings files (these do not contain personal info), so that I can try to replicate this issue (testing it on Windows 10).
