Layers Panel trashcan deletes text from Text on a path one character a time
In one instance, the Layers panel trashcan deletes/truncates characters in a text element connected to a path one character at a time from the beginning of a text string. So something isn't working correctly there. Remaking the path and connecting some text with it doesn't reproduce the issue and I had even tried duplicating it as I had done that before with <Enter>. I'll try to see if I can get it to reproduce.
Video:
https://1drv.ms/v/s!AuWHX0h5bAoRio4nQTSp5NJ9r6UJBQ?e=zFH2M3
@debraspicher Can be replicated here also. Will be fixed for the next build.
This happens only when the text editor is active.
