update 1.2.030
VectorStyler 1.2.030 release notes
- Added a global color mode option to generate color palettes for new documents.
 - Added copy and paste commands to the shape preset drop down for easier shape transfer.
 - Fixed a global color handling bug.
 - Fixed a template artboard refresh issue.
 - Fixed a template selection issue with duplicate templates.
 - Default artboard size can also be set in Canvas options.
 - Update the offset path indicator in wireframe mode.
 - Added support for Unicode extension planes in TTF fonts.
 - Improved handling of shape closing in the path sketch tool.
 - Editable text inside compound shapes.
 - Drag and drop improvements in the Layers panel.
 - Do not open large preview when dragging from the layer preview icon.
 - Composite shape operator in menu to show selected mode.
 - Erase block modifier to work on selected shapes only.
 - Mirror tool to position objects correctly.
 - Allow selection and copy from Unicode field in the glyph panel.
 - Indicate empty layers and groups in the Layers panel with a different opening icon.
 - Improved handling of stroke attributes in the Pencil tool.
 - Option to move locked objects when moving artboards.
 - Duplicating artboards from the canvas panel to consider bleed for spacing.
 - Document level option to not show fill for open paths.
 - Added alternate editor modes to the reflect and corner tools.
 - Improved Transform panel layout.
 - General stability improvements.
@VectorStyler Very nice. Looking forward to updating.
@VectorStyler Keep up the great work! I appreciate the consistent updates and improvements to VS
