Click and Drag to Add to selection is not working in new build 31
@VectorStyler said in update 1.2.031:
Shift+Click should deselect single objects.
With the new update to build1.2.031, the ability to hold down the shift modifier to drag and select additional nodes to an existing selection is gone. I think it ties in with the new feature, "Shift+Click should deselect single objects."
You can still click each additional node individually to add it to the selection, but you cannot click and drag to add more all at once.
@Boldline I will try to replicate this.
@Boldline The problem can be replicated. I will release a fix today.
