The new pasting method
VS needs to add a new pasting method. By default, it can only be pasted in the original position. In many scenarios, pasting at a specified location is required. Currently, the only way is to click on the graphic and press ALT to drag it to the specified location. If it is outside the view, the dragging distance will be longer. There is an urgent need for a new pasting method. The normal procedure is "paste in view". Inkscape uses the mouse position, which are all very good options. I prefer the latter.It is hoped that this function can be added
@monsterfox I added this to the backlog.
Just for inspiration
Magix Designer / Xara use the right Mouse Button
to copy a Shape. Drag a Shape with the right Mouse Button
to a new position and it will be copied.Corel Draw use also the right Mouse Button
but with a little Menu
