The problematic text crashes when moved
I cannot replicate this problematic text. Resolving the issue with this text simply requires refilling the colors. This problematic text randomly crashes when moved.
0_1729875054851_TEXT ISSUE.vstyler
https://youtu.be/QvVJtBgiMgA
https://youtu.be/Abbq6MWy75k
https://youtu.be/ZaD4Y9KdRkg
https://youtu.be/mxC_ZUiUkbE
@Li-Xiao Open the Appearance panel and select the whole text with the text editor.
There is a "Brush" style on the text. The brush width is 31.9 pt and the font size is 28 pt.
Stretching a brush of this size on those curves creates the problems.
I recommend removing that brush.I will try to replicate the crash (and look into the crash logs also).
@VectorStyler I forgot to check the appearance in text editor mode. now I understand. Thanks. I'll send the crash logs file to you.
