"-" (minus) key to delete nodes inserted with the "+" key ?
We can inserte Nodes on to a shape via pressing the " + " Key
but it seems there is no such way to delete such inserted Nodes.I thought of mine was how about using the " - " (minus) key
for that or any other way ?See this Post here
https://www.vectorstyler.com/forum/topic/4854/node-tool-drag-select-short-key-how-do-i-select-and-activate-every-nodes-in-same-shape/7Well, I have to say that I'm not sure if this is actually a good idea
but I just wanted to post it
@Subpath You can delete with the "delete" key.
i know i can delete using the Delete key
but only for newly inserted Nodesi was talking about reverse these Steps (delete the Nodes)
in the direction there was insertedHere a video about it
But I would say forget about this suggestion for now,
this may be perhaps a too special caseIt is a bit more complicated but in the end you can select
the nodes you want to delete.
