update 1.2.054
VectorStyler 1.2.054 release notes
- Option to allow using (linked) object styles as default drawing styles.
 - Improved alignment of number sliders.
 - Converting a single glyph to curves should result in a single object, not a group.
 - Fixed a refresh bug when changing styles inside transformed groups.
 - Allow click selection of parametric shapes in the node editor.
 - Convert to curve should be disabled if no conversion is possible.
 - Show color palette margins inside popover views also.
 - Changed the popover window style.
 - Creating number variables should check for name overwrite.
 - Do not paste text into a shape text as a frame.
 - Improved exporting blend modes to SVG and PDF.
 - Fixed a bug in breaking apart cloned objects.
@VectorStyler said in update 1.2.054:
Yeah, I suppose this is what made Verctorstyler beautiful again?
@Ingolf THis change was about the removal of the pointing bubble frame around view opened from buttons
Perhaps fixed my issue with panel corners as well? I believe something wonderful happened in this or the previous release.
@Ingolf said in update 1.2.054:
yes, some outlines are thinner now.
