XLS for features and ideas - Megathread
Embed External Image File: Don't know what your plans are for developing a dedicated image editor (PictureStyler?). If you have no such plans (I'd actually prefer this as you can focus exclusively on vector editing) , then here's an idea: Allow users to embed an image file within VS (like Placeholder objects in PL, and Smart Objects in PS, and linked files in Affinity). Then, allow users to click through to a dedicated image editing app (I recommend PL), make their edits and come back.
The reason I recommend PL is because PL already supports external applications. Exactly as I've described here. You can open any object in an external application just as long as that external application saves in the same location, over the same file, as you were working on when you were inside PL. The support formats are TIFF, JPEG and PDF. That is broad enough for most use cases.
This might not be an easy task to accomplish. Might want to slot in for the long term roadmap.
That is my official 100th post on the forum!
Contextual changes to the colour swatches upon selecting objects. Indicating stroke, fill, and gradient stops.
Close all files without saving and return to files, to the current scroll location in each file.
Thumbnail view on hover over the files tab. If multiple files are open in VS, allow a thumbnail view on hovering over the tabs.
@Daniel said in XLS for features and ideas - Mega Thread:
This is not clear: where is the current scroll location ? Is the a "reveal file" type of action?
@VectorStyler: What I mean is, if I am working on multiple untitled files and don't have the time to save it all, then I just want to close the program without a prompt to save. Then when I reopen the program, I want to come back to where I left off. And in each file, I want to be able to find myself in the same zoom level and scroll location. Scroll location might be confusing because VS does artboards and not pages. Think of a multipage document and you're on page 15. You close and come back to the exact same spot. Every time. In VS's case, this does not apply. You just need to come back to the same artboard and zoom level.
If I have 5 documents, and on document 1, you have three artboards, and you're zoomed into 1500% on an object on artboard 3. Then, when I close and come back, I want to come back to the same place, where I left off. I want to have this in each of the 5 documents.
For reference, see XDP.
If you're as disorganised as I am, this is makes life so much better.
Alternatively, as an addition, there should be a simple tick box within the save prompt window, to "do the same for all files".
White Space Preview: A toggle to turn all text into black blocks. Like so:
Useful when trying to see the document for visual impact.
Visual alignment panel. This is much speedier than the normal iconized alignment options. Providing greater visual feedback. I also think there should be a constraint option baked into alignment. Logically related and sequentially performed. Therefore group tool options.
The problem with this approach is that it needs a separate "Apply" button. So even if the alignment is just a regular "horizontal-left", you will need 2 clicks to do it. The current approach needs one click only for this.
@VectorStyler: That is true. But as I explained, this is not the only option possible. It is an additional panel alongside the iconized alignment options. And it need not contain the apply button. It can be a simple direct click to apply. Further, having the option to modify click within the panel also reduces cognitive load. I only have to click in one place. Alt click for Horizontal. Ctrl click for vertical. Check this out in XDP to get a feel for it.
Having said that, I think the alignment panel in Inkscape is by far the most advanced and useful of all. If you've not checked it out, highly recommend it.
Also, I reckon there should be a node align panel too.
... Also, I reckon there should be a node align panel too...
You can already align nodes using the alignment tools
and Node Handles too, so i dont see a reason for that
This post is deleted!
@Subpath: Yes, this is not necessary. Agreed.
@monsterfox: Please could you fork this out into a dedicated bug thread. I don't want it to get lost here.
 Thank you!
@VectorStyler: Actually, there's a much simpler, more contextual way of doing this. Inkscape got this right. Provide direct, on-screen alignment handles for the the basic and most common alignments. It is exactly similar to aligning text blocks and is very useful.
Spray symbol without calling the tool. Using + number pad when moving a symbol (or group of symbols).
Not clear how this would work. You can insert one or more symbols by dragging from the panel but that will not work as a spray.
Would pressing "+" activate the spray symbol tool?
@VectorStyler: you have created symbols. Now with the select tool active, you make a sequential selection of all your symbols. Then you press escape. Now, when you press + repeatedly, the select tool places the symbols you selected in the same order you selected them. If there's only one symbol, then, that symbol gets stamped. Every time you plus +.
Sort of "insert symbol at the current mouse position" ?
@VectorStyler I'll explain this much more clearly tomorrow.
