Can't expand text on path
It seems that text on path can't be expanded.
If I convert it to curves, it turns into regular text.
Is there a solution?
Thanks
@Fertuffo Exported to what format?
Expanded, not exported.
Expanded in a way that text is a shape with nodes
@Fertuffo Sorry, I was in a rush.
I can convert it to curves here.
EDIT: with both the curve and the text selected.
Otherwise it will just release it.
@Fertuffo Yes, single text on path conversion has a regression.
Ok, so you can confirm the bug
Thanks
@Fertuffo Fixed!
