Improve Node Bump Effect
@VectorStyler Applying node bump to lines didn't meet expectations.
0_1747190012343_Node Bump.vstyler
Add more detailed options similar to Circular Bump distortion.
Add an option to selectively apply the Node Bump effect to specific nodes, using shapes or text as selection sources.
@Li-Xiao I added this to the backlog
@VectorStyler The 1.2.072 has made improvements to the lines. Thank you so much.
@Li-Xiao There is a new Node Bumb effect option now that controls how to handle groups.
By default is off, but when turned on the center will be the group center.
@VectorStyler Yes, I noticed. The center(x y) still can't be moved.
@VectorStyler I can freely move the center of the node bump effect now. Thanks a lot!
It would be great if the position pointed by the arrow could be optimized to make the spacing between curves more uniform.
Filling the outline with gradient colors slows down the file speed significantly.
0_1749313645797_Node Bump.vstyler
@Li-Xiao I opened a bug on this.
For this type of effects you may also want to check the Displacement distortion.
@VectorStyler Displacement distortion has its unique characteristics, but Node Bump creates a unique effect not found in other software.
These pics, simply spectacular.
I'm always impressed by your results.
@Subpath VectorStyler offers a myriad of impressive features; most of the optical illusions graphics sold on vector graphics library websites can be created using VectorStyler.
@Li-Xiao said in Improve Node Bump Effect:
@Subpath ... VectorStyler offers a myriad of impressive features ...
Of course I know that, but your discoveries are on a completely
different realm. I love them.
